Hi all!
I want to upgrade 16.2 to 20.1, bit it faied with follwoing error:
No matching assembly located in available assemblies Infragistics4.Win.UltraChart.v16.2.Design at Infragistics.VersionUtilitySupport.Core.Product.AssemblyXmlFile.ThrowExceptionWhenAssemblyCouldNotBeFound(String assemblyName, Boolean checkAdditionalMessage)
I did already changed the path in the upgrade options -->Control Assemblies Path without success.
Any ideas?
Greetings
Wolfgang
The project's license.licx might have an entry with ultrachart that can be removed. This file can be emptied.
The project file's code might have an entry in which you can unload and edit or edit in a notepad and see if it's there.
Thanks for your answer.But WHERE to remove? There is no Reference in the Project to UltraChart.
Hello Wolfgang,
Thank you for contacting Infragistics. It appears the upgrade utility is looking at a design assembly for the chart. Projects won't need design assemblies so you can safely remove it and rerun the upgrade utility. After it's removed, do a clean and rebuild of the solution. Let me know if you have any questions.
