How do you change the Null Text appearence? The UltraTextEditor exposes a NullText Appearance property but I cannot find anything like this for the combobox.
Richard,
I still do not see a NullTextAppearance. You should also contact Developer Support on this matter, since the more people that request a feature, the more likely it is to be implemented. It could also be argued, as Mike said, that is an oversight and may be considered a bug.
-Matt
Did this get requested, I cannot see it?
Richard
Hm. That seems to be something of an oversight. If the control does not have a NullTextAppearance, then what you could do is trap the ValueChanged event and set the Appearance based on the current value.
You should probably also Submit a feature request to Infragistics or maybe even report this to Infragistics as a possible bug: Submit an incident to Infragistics Developer Support
