455
Supress new template add row
 Hi
How to suppress the new template add row when the user starts typing in the template row? I have set the AllowAdd property to TemplateRowOnBottom. I would like to add a new template row only when the user clicks on the row selector image or when the template row the user entered has valid values.
  • 71886
    Hello gomadams.
    You could read about suppressing this in the following thread:
    http://forums.infragistics.com/forums/t/12252.aspx.
    Also, you could use a code like the following in order to achieve the desired behavior:
    private void ultraGrid1_AfterSelectChange(object sender, AfterSelectChangeEventArgs e)
                if (e.Type.Name == "UltraGridRow" && ultraGrid1.ActiveRow.IsAddRow && ultraGrid1.ActiveRow.GetUIElement().ChildElements[0].PointInElement(ultraGrid1.PointToClient(MousePosition)))
                    Console.WriteLine("A selector was clicked, please perform the actions here");
    Please do not hesitate to ask if something comes up.
