I have a report in format A5 (front- to back) that will show two tables. These tables are a unique ultragrid where it shows different columns.I made a dynamic selection by doing from the initializelayout of the child grid which fetches data from a parent grid then in button click event create my report with print settings.
For my section I would like to display these two tables so that one of them is rotated in reverse from the other. I tried to create two different sections but it only displays the first table and not the second (to do this I used the Export method of an UltragridDocumentExporter)
Are there any solutions to my problem?I saw that report a advanced layout elements called rotator but it is only used for strings and I don't know if it is possible to do it from a grid
Hello Ca,
For future reference, if your post doesn’t show up right away, please keep in mind that we have a moderation queue so your post will need to be moderated prior to it showing up.
Regarding a solution to the issue(s) you are seeing, I know above I had recommended a reorganization of the columns in the UltraGrid you are looking to export, as I was under the impression that you were looking to essentially reverse the order of the columns? Perhaps I was under the incorrect impression though, and if so, would it be possible for you to please elaborate further on why this doesn’t work for you?
Thanks for reply!!
Yes I created two same topics, because I had have problems to create a post (sorry)
Unfortunately I think that there aren't solutions for my problem i guess.
I have been investigating into this behavior in another forum thread that you have created, here: www.infragistics.com/.../create-a-report-from-ultragrid-with-2-section-distinct
I have recently provided an answer to that forum thread regarding this rotation of an UltraGrid in a report in that: I don’t believe the IRotator will help you here, but since you have mentioned that you are getting a unique set of columns, I would recommend reorganizing those columns in your UltraGridBand such that they are essentially reversed, as this should have the same effect.
