Did the default theming algorithm for theming change between 2008.1 and 2008.2? My app uses the Office2003 ToolbarStyle and it used to use the colors of the current desktop theme.
2008.2 appears to work the same way EXCEPT when I use a "non-standard" theme, in this case Microsoft's Zune theme for XP which happens to be my current OS theme. In this case, the colors default back to the Office-blue look.
I have attached an image showing the problem (2008.1 on the left, 2008.2 on the right). The source is the same, the only difference is the version of assemblies I am referencing.
How do I get the 2008.1 behavior back?
A bug has already been created (BR35743). It looks like this is also happening for our users who have the XP set to the Classic theme.
This looks like it might be a bug, but I'm not sure what could be causing it. I would recommend submitting it to the support group so it can be investigated further: http://ko.infragistics.com/gethelp.
