I am having a UltraComboEditor, which has Items Like "Select All, a, b, c". If I check "Select All" it should check all the other Items and vice- versa on un-check of "Select All". Here the issue I am facing is that, when we check "Select All", the Text property should be updated with the remaining items name except "Select All".
eg:- Currently I am getting the Text property value as "Select All, a, b, c,". But I need the text property should be modified to "a, b, c"
I am using Infragistics version 15.1
Hello ,
This post is duplicate of this one, which i already answered.
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/122958/ultracomboeditor---all-should-be-ignore-in-the-textbox-area
we can continue discussing the matter with one post.
