Hi ,
I am using Infragistics Ultimate 20.2 trial version in my application in my dev machine. Now i want to get it tested by QA team. So when i try to run on application QA's machine it's not working. Is there any limitation with trial version to not use on more than one machine?
Thanks... Shailendra
Hello Shailendra,
Thank you for contacting Infragistics. There should be no issues moving an application with our assemblies to another machine (without the tools installed). As long as the bin folder or where your app is expecting the assemblies is coped over then the app should run. The QA tester(s) should not be required to install any of our tools (unless they have to use the Visual Studio designer). In that case, they should probably create their own accounts and start a separate 30 day trial and proceed with testing. I am curious what issue are you having on the QA machine. Please clarify. Thanks.
