Hi Infragistics Team,
i just installed the first preview of Windows 11 and had a look an the design changes. Microsoft introduced some new shiny stuff for standard controls like textboxes. They now have a thicker line on bottom which becomes blue if the control gots the focus.
Microsoft also has an update for .NET-Framework where they introduced this changes for the standard .NET WinForms Controls.
I know it is quiet an early stage, but du you already have plans to also upgrade Infragistics Toolsets to fullfill the new design standards for Windows 11. Because currently out app looks quiet ugly on Windows 11. It does not totally fit into the rest of the applications.
Regards
Andreas
Any update on this please?
Microsoft has released Windows 11 a couple of months ago. I'm not seeing any announcement on your Web site regarding Windows 11 design. When are you planning to provide an updated version of Infragistics?
Hugues
If Microsoft decides to stick with this current default design then we may implement ours the same way and you will have to change the border regardless whether you will use ours or the MS text box. It just depends what we deem appropriate. It’s possible we don’t follow MS. But it’s too early to tell, MS might end up changing before RTM Windows 11.
thanks for the response. What I would like to see is that the infragistics control will look like the standard controls with the next version. For us it is not an option to go through the whole application and change the border style of all textboxes to have it look the old way.
Hope to see that on the roadmap.
Best regards
Note, setting the MS Textbox BorderStyle to FixedSingle will remove the line. So it's a design change to their Fixed3d that uses the line.
