we are using the UltraGrid from Infragistics and translate all text in different languages.We have a lillte problem to find the property from this grid:
http://www.bilder-space.de/show.php?file=wwKz0oBSxwZ2HFI.png
I'm not sure what property you are looking for. The image you linked to here has a box around what appears to be a column, but it's also containing a groupby row and some other things.
The name of a band comes from the data source and cannot be set by the grid. You can set the Caption on a Band or on any column you want, though. To set the column caption, you would use column.Header.Caption.
