I have a grid with a number of columns, two of these are Name and orderID. We allow the user to use the group by function by dragging a column to the group by box. So if they drop the name column there, it groups on name and then the group by rows are sorted in name order. I would like the group by rows to always be sorted on the orderID. How can I accomplish this?
Sincerly,
Gabriel
Hi Mike,
Thank alot, it works wonderfully now.
cheers,
The GroupBySortComparer property is on the column. You would probably do this in the InitializeLayout event of the grid.
Where would I set this Comparer? And in what event?
Hi Gabriel,
You can sort the GroupByRows using a GroupByRowSortComparer on the column. You will need to create a class that implements IComparer.
