70
set Bottom border for UltraGrid Header
Hi there,
I want the header of my UltraGrid to have a border only on the bottom
First I tried by Implementing the IUIElementDrawFilter and in the Draw Element function, I managed to draw a bottom line for my header. But the line is having weird behavior. If I point my cursor at the header, It sort of disappears and when I click on the header the line appears (kindly see the attached video below)
Then I tried implementing the IUIElementCreationFilter Interface and inside the AfterCreateChildElements function I check if the UI Element is HeaderUIElement so that I can set the BorderStyle and BorderSides properties but this throws me an “Specified method is not supported.” error.
Here is the Link (https://www.transferxl.com/04jYdDShFBDnYj) for my project with the exact code I wrote for both interfaces (IUIElementDrawFilter and IUIElementCreationFilter)
Kindly look into this and help me in this regard
Regards.
