It will be helpful if you teach me workaround or some hint about following phenomenon.In Windows 11 preview, on the TabbedMdi close button shown as TabCloseButtonLocation.HeaderArea, a dark gray holizontal line is displayed.
The line become thicker on mouse-over the button. The behavior is similar than the scrollbar of Windows 11.The phenomenon occurs in case that PropertyPageSelected is set to TabGroupSettings.TabStyle.(And PropertyPageSelected is indispensable to our application.) Version: NetAdvantage v12.2 and Infragistics_WinForms_20211_SamplesWindows Version: 22000.132 ~ 194, 22454 on Hyper-V / VMWareVisual Studio 2015 (for main use), 2019 (for investigation)Thanks in advance.
This has been resolved in the a latest version available eg. v22.2 build 27
I have created a private support case for you to continue our discussion. It has an ID of CAS-214212-C8X5Y6, and you can access it after signing into your account on the Infragistics website, here: https://ko.infragistics.com/my-account/support-activity.
Thank you for your support.I can see that the issue is solved in simple application.In relation to that, let me some confirmation:* If there are multiple NetAdvantage components that inhelits UltraControlBase in an application, is it necessary to set SupportThemes=false for all components?* Is there any possibility that other component affect the status of UltraTabbedMdiManager.SupportedThemes?* Is there any possibility that other property than SupportedThemes in UltraTabbedMdiManager (except UseOsThemes) affect the status of SupportedThemes?
Hello and thank you for contacting Infragistics. I tested against Windows 11 22000.194 and I can reproduce this behavior and not on Windows 10. It's an issue with our theme/hot track buttons. You can prevent this by setting SupportThemes to false on the tabbledmdimanager. However at this time we don't have an ETA on Windows 11 support.
