i've tried to use the MaterialDesign-Font ais Font in an UltraButton. This works, but the Text in Ultrabutton seems not vertically centered. The text is a little bit above, only 1...2 Pixel.
Am i doing something wrong?
In the program you can see the effect on the Exit-Button in the right corner. If imove the mouse over the button, the you can see that the margins of the exitsymbol are not equal.
Greetings, Karsten.
You can refer to this product lifecycle page . As per support lifecycle currently we bug fix the version V20.2, V21.1 only.
Let me know if you have any other question.
Hello Divya,
thank you for checking my problem.
About using 18.2.: Our subscription has ended and unfortunately we are no longer able to download the latest version of our subscription, otherwise we could switch to 19.1 wich is our latest available key. If the problem above can be solved by using 19.1 then it would be nice, if we could download this version. If the solution needs a higher version then i have to talk with our shopping department...
Greetings from Germany, Karsten Heimer.
Hello Karsten,
Thank your for contacting. I am able to reproduce the issue , I noticed that you are using version 18.2,
Please note that volume18.2 has already had its last service release so if the resolution of this development issue requires a change to the assemblies it will be necessary to upgrade to a more recent volume of Infragistics .
In response to this issue being logged, I have opened a new private support case for you that I will be linking to this issue so you can be notified when a fix or other resolution becomes available. This private case has an ID of C-00220050 and you can access it here: account.infragistics.com/support-cases
This is, what i expect:
MaterialFontDemo.zip
