I am new to Infragistics, and just inherited a .NET C#/VB solution where I was asked to upgrade (Windows Forms) from 19.2 to 21.2. Previously, we've deployed our product with ~10 Infragistics DLLs, but no explicit license file. Also, we are not using Nuget packages, so the DLLs are part of our solution, and the various projects have references as need directly pointing to the DLLs. Here is what I've done and where I am stuck:
I am guessing there is something basic that I am doing incorrectly, so any help/advice on this would be greatly appreciated. (Also, any explanation of where exactly the license info is stored, if it is not actually embedded in the DLLs.
Thanks in advance!
Larry
I am glad that you managed to achieve your requirement.
Let me know if you have any further questions on this matter.
Regards,Teodosia HristodorovaSoftware DeveloperInfragistics
Update: after a totally clean uninstall, re-install to get the new DLLs, and then also actually un-installing before building my solution, the TRIAL license notifications disappeared.
Thanks!
As it is mentioned in our License Agreement here, Infragistics Ultimate including Windows Forms is licensed for full use per registered developer. The software may be installed and used on more than one computer or on a network server, as long as the use of it is limited to the named, registered developer for whom a license fee has been paid.
Having in mind that the license is tied to the developer, it is expected only you to be able to access the licensed version. If you have more questions about licensing, my suggestion is to contact our sales department at sales@infragistics.com. They will be glad to assist you and provide more details.
In addition, in order to be able to take advantage of your license, my suggestion is to register your product key in your account under the Product registration section (attached screenshot).
Let me know if I may be of any further assistance.Sincerely,Teodosia HristodorovaSoftware Developer
