50
UltraExpandableGroupBox - Size
I have added a UltraExpandableGroupBox inside a TableLayoutPanel row and trying to add a TableLayoutPanel to the UltraExpandableGroupBox dynamically. Here I need to set the UltraExpandableGroupBox size depends upon it's child control(here it is a TableLayoutPanel)
Code:
private void Load(List<StudentInfo> students)
var tableLayoutPanel = new TableLayoutPanel();
tableLayoutPanel.ColumnCount = 3;
tableLayoutPanel.ColumnStyles.Add(new ColumnStyle(SizeType.Absolute, 100F));
tableLayoutPanel.ColumnStyles.Add(new ColumnStyle(SizeType.Percent, 250F));
tableLayoutPanel.Dock = DockStyle.Fill;
tableLayoutPanel.Location = new Point(0, 0);
tableLayoutPanel.Margin = new Padding(4);
tableLayoutPanel.Padding = new Padding(4);
tableLayoutPanel.Name = "studentsTable";
tableLayoutPanel.RowCount = 1;
tableLayoutPanel.RowStyles.Add(new RowStyle());
int rowNumber = 0;
for(int i=0; i <= students.Count; i++)
var rowIndex = rowNumber > 0 ? AddTableRow() : rowNumber; // here adding a new row to the table
Control firstName = RichText(students[i].fName);
_demogViewControls.HistoricalAppointments.Controls.Add(firstName);
_demogViewControls.HistoricalAppointments.SetCellPosition(firstName, new TableLayoutPanelCellPosition(0, rowIndex));
Control lastName = RichText(students[i].lName);
_demogViewControls.HistoricalAppointments.Controls.Add(lastName);
_demogViewControls.HistoricalAppointments.SetCellPosition(lastName, new TableLayoutPanelCellPosition(1, rowIndex));
Control studentAddress = RichText(students[i].sAddress);
_demogViewControls.HistoricalAppointments.Controls.Add(studentAddress);
_demogViewControls.HistoricalAppointments.SetCellPosition(studentAddress, new TableLayoutPanelCellPosition(2, rowIndex));
rowNumber++;
studentsGroupBox.Panel.Controls.Add(tableLayoutPanel); // studentsGroupBox is a UltraExpandableGroupBox, added in UI (___.Designer.cs)
studentsGroupBox.Height = tableLayoutPanel.Height;
It will bee great if anyone can help me on this regard.
Thanks in advance,
Top Replies
