in development, row select tab is there. When I publish the project and install it on a client, the row select tab on a grid disappears. Using version 19.1 of infragistics on visual studio platform 2022. Windows Ultragrid.
Thank you for sharing the images. Looking at them i don't see style also been apply in your new environment.
So if you have all the dlls in place then check if you are missing your isl file to deploy ?
I would not recommend to hard code anything ,since everything is working fine in the development environment.
Above is with tabs in dev platform
Below is without tabs when installed
not sure what is causing this. I went in to displaylayout.overrides to hard code it in.. still did not come up in installed environment.
Thank you for contacting. Can you share any image to explain what do you mean by row select Tab.
My guess is may be you are missing any dll? Compare your dev environment with client environment and see if you find something important is missing?
