context: using ultraGridFilterUIProvider for excel alike filters on datetime columns. (Infragistics4.Win.UltraWinGrid.v18.1, Version=18.1.20181.88)
my issue starts when i try to set a stored/recreated value for a filter on my application.
Infragistics.Win.UltraWinGrid.ColumnFilter columnFilter = getColumn();Infragistics.Win.UltraWinGrid.FilterComparisionOperator filterOperator = getFilterOperator();object value = getStoredFilterOperand();columnFilter.FilterConditions.Add(filterOperator, value);
I can set a value with a DateHierarchyFilterOperand instance, but I cannot instantiate a MonthOperand nor a RelativeDateOperand nor a QuarterOperand instance, since these class are internal. So I am not able to set a filter condition with any of these.
Any advice will be appreciated.
that info helps a lot.
a related and useful method would be
GetRegisteredOperand
thanks!
Hello JD,
Thank you for contacting.
I believe you need this filter operand instead.
https://ko.infragistics.com/help/winforms/infragistics.win.ultrawingrid~infragistics.win.ultrawingrid.specialfilteroperands_properties
Let me know if this helped.
Regards
