I was wondering if there was an easier way to select a specific row when multiple group by's are involved. Clearly the code below will allow me to select the row I am looking for with only one group by is used but it is useless if more than one is used.
Do I have to create a recursive loop to accomplish this?
If so probably not worth it. We select the row based on a row cell we know to be unique. In this case we pass in the customer to select and trap on it. Once the customer is found we select, activate the row and kick out.
if (this.grid.Rows.IsGroupByRows) { foreach (UltraGridGroupByRow groupByRow in this.grid.Rows) { foreach (UltraGridRow row in groupByRow.Rows) { if (row.Cells["Cust_id"].Text == customerToSelect) { this.grid.ActiveRow = row; this.grid.ActiveRow.Selected = true; break; } } } }
Sorry I missed this method. I figured there had to be a method to do this for me. My bad.
Hello Michael,
The Rows collection of the UltraGrid actually has a method named GetAllNonGroupByRows that I believe would help you with this. Rather than trying to recursively loop through the GroupByRows, you can invoke:
ultraGrid1.Rows.GetAllNonGroupByRows();
Then loop through the resulting collection and select your row in the way you are currently doing.
