190
Ultra Toolbar Manager Crashes
Ultra Toolbar Manager Crashes without doing any activity even if application is in idle state
You can see the toolbar in following image:
Crashed Toolbar in following image:
Following file has error details:
New Text Document (2).txt
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): The handle is invalid
   at System.Drawing.Graphics.CopyFromScreen(Int32 sourceX, Int32 sourceY, Int32 destinationX, Int32 destinationY, Size blockRegionSize, CopyPixelOperation copyPixelOperation)
   at System.Drawing.Graphics.CopyFromScreen(Point upperLeftSource, Point upperLeftDestination, Size blockRegionSize)
   at Infragistics.Win.ControlUIElementBase.CaptureOldImage(UIElement element)
   at Infragistics.Win.TransitionInfo..ctor(UIElement element, Transition transition, TransitionSettings settings)
   at Infragistics.Win.ControlUIElementBase.InitiateTransition(TransitionSettings settings, Transition transition, UIElement element)
   at Infragistics.Win.UIElement.InitiateTransition(TransitionSettings settings, UIElementTransitionType transitionType)
   at Infragistics.Win.UltraWinToolbars.Ribbon.RibbonTabManager.MouseLeaveTab(ITabItem tab)
   at Infragistics.Win.UltraWinTabs.TabItemUIElement.OnMouseLeave()
   at Infragistics.Win.ControlUIElementBase.ElementEntered(UIElement element, Boolean triggerMouseLeavesOnly)
   at Infragistics.Win.ControlUIElementBase.SyncMouseEntered(Boolean triggerMouseLeavesOnly, UIElementInputType inputType, Boolean ignoreLastElementEntered)
   at Infragistics.Win.ControlUIElementBase.VerifyIfElementsChanged(Boolean verify, Boolean syncMouseEntered)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
   at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
   at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
   at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.OnPaint(PaintEventArgs pe)
   at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
   at System.Windows.Forms.Control.WmPaint(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4110.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
XHawkSurveillanceSystem
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/XHawkSurveillanceSystem.exe
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    Win32 Version: 4.8.3761.0 built by: NET48REL1
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Infragistics4.Win.v12.1
    Assembly Version: 12.1.20121.1001
    Win32 Version: 12.1.20121.1001
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.v12.1.DLL
CommunicationController
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/CommunicationController.DLL
CommonControls
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/CommonControls.DLL
WindowsDesktopAlerts
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/WindowsDesktopAlerts.DLL
Infragistics4.Shared.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Shared.v12.1.DLL
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
CacheController
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/CacheController.DLL
System.Deployment
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Administration
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Administration.DLL
Infragistics4.Win.Misc.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.Misc.v12.1.DLL
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Infragistics4.Win.UltraWinTabControl.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinTabControl.v12.1.DLL
Infragistics4.Win.UltraWinEditors.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinEditors.v12.1.DLL
System.Security
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Domain
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Domain.DLL
InteropBridge_Win32_Release_100
    Assembly Version: 1.0.7671.21352
    Win32 Version:
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/InteropBridge_Win32_Release_100.DLL
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
DatabaseController
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/DatabaseController.DLL
System.Data.OracleClient
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Data.OracleClient/v4.0_4.0.0.0__b77a5c561934e089/System.Data.OracleClient.dll
System.Transactions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
QPidCommunicationManager
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/QPidCommunicationManager.DLL
AuditTrail
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/AuditTrail.DLL
Infragistics4.Win.UltraWinToolbars.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinToolbars.v12.1.DLL
Infragistics4.Win.UltraWinDock.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinDock.v12.1.DLL
Infragistics4.Win.UltraWinTabbedMdi.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinTabbedMdi.v12.1.DLL
Infragistics4.Win.UltraWinGrid.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinGrid.v12.1.DLL
Infragistics4.Win.UltraWinChart.v12.1
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/Infragistics4.Win.UltraWinChart.v12.1.DLL
System.Data.DataSetExtensions
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Data.DataSetExtensions/v4.0_4.0.0.0__b77a5c561934e089/System.Data.DataSetExtensions.dll
QpidClient
    Assembly Version: 0.5.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/Capizar%20MSS/CapizarMSS/QpidClient.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  • 29105
    Hello and thank you for contacting Infragistics. This issue can occur anytime the control has issue painting. An examples of this is if you are using multiple threads and the control is accessed on another thread or using an instance of control that may have been disposed or closed from the toolbar. I suggest attaching a sample demonstrating the issue.
    This was previously discussed here:
    www.infragistics.com/.../understanding-the-big-red-cross-x
