Is it possible to "see through" a hot-tracked row?
What I mean by this, is that if I have an UltraGrid with individual cells with Appearance.BackColor set, to indicate different statuses. I want to enable a hot-tracked row which has an Alpha level with partial transparency. So if I hover over a row which has certain cells coloured, I still see those colours through my hot tracked row?
If I set HotTrackRowAppearance, it only colours any rows without cell appearance set.
If I set HotTrackRowCellAppearance, it colours all cells in the row, but it overrides my individual cell colour.
Ideally the Cell should have a HotTrackRowAppearance, so if I set the appearance on the individual cell I could also set the colour when my hot track row is over the cell, but this doesn't appear to exist.
Is there any other way to do this?
Please provide a mockup screenshot of your desired behavior.
Something like this:
The hot-tracked row is red 25% opacity. When it hovers over the blue squares, they become purple, and the green gets darker.
4338.WindowsFormsApp1.zip
That's great, thank you. I missed the fact that I needed to set AlphaLevel directly on the appearance, rather than on the colour itself.
Your welcome.
