20
Null reference exception in PointAlongLineHelper
How to find out what is getting a null reference?
Is the source code available if there is a license?
System.NullReferenceException: Object reference not set to an instance of an object.
at Infragistics.Controls.Charts.PolarBase.PointAlongLineHelper(Point world, Boolean visibleOnly)
at Infragistics.Controls.Charts.PolarBase.GetItemIndex(Point world)
at Infragistics.Controls.Charts.PolarBase.GetItem(Point world)
at Infragistics.Controls.Charts.Series.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.MarkerSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.PolarBase.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.PolarLineSeries.PropertyUpdatedOverride(Object sender, String propertyName, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.Series.<.ctor>b__16_1(Object o, PropertyUpdatedEventArgs e)
at Infragistics.Controls.Charts.PropertyUpdatedEventHandler.Invoke(Object sender, PropertyUpdatedEventArgs e)
at Infragistics.Controls.SeriesViewer.RaisePropertyChanged(String name, Object oldValue, Object newValue)
at Infragistics.Controls.Charts.SyncLink.CrosshairNotify(SeriesViewer sender, Point crossHairPoint)
at Infragistics.Controls.Charts.SeriesViewerInteractionManager.OnContactMoved(SeriesViewer target, Point pt, Boolean isFinger)
at Infragistics.Controls.SeriesViewerView.OnContactMoved(Point p, Boolean isFinger)
at Infragistics.Portable.Controls.EventProxy.RaiseOnContactMoved(Point point, Boolean isFinger)
at Infragistics.Win.DataVisualization.WFEventProxy.Target_MouseMove(Object sender, MouseEventArgs e)
at System.Windows.Forms.MouseEventHandler.Invoke(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseMove(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseMove(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  • 7535
    Hello Peter,
    Yes we do provide source code to license customer , which you can download from your infragistics account at https://account.infragistics.com/downloads
    Which version of control you are using ? I believe you are getting this exception with the ploar series , we had some issue in the past we is fixed now , so you can even download the latest trial version and can verify that , if issue is fixed , you cant reproduce with latest then you can upgrade to the latest .
    Regards
