I set a bunch of named references in my code which the user can then use in formulas through the formula builder. Some of the calculations involve dividing by that value, which can be 0. Instead of forcing the users to test if that value is 0 when dividing by it is there a way to catch this error?
None of the events of the UltraCalcManager fire but there is a OverflowException thrown when setting the formula property of the column. I set the FormulaErrorValue of the column but I still receive the exception. How can I prevent this from occurring?
The only way to do that would be to use a CreationFilter or DrawFilter. I'd go with the CreationFilter, myself. You can trap for whatever UIElement in the grid is drawing the summary text and just set the Text property on the element.
I recommend that you get the Infragistics UIElementViewer Utility. It will be a big help in determining which element(s) to look for.
I have the event fire correctly when a division by zero occurs, but I cannot suppress the #DIV/0! message that is now showing in the summary.
Is there any way of making sure this message is not shown? As far as I can see while debugging is that the message is the result of e.ErrorInfo.Code.
Problem is, everywhere I find this code during debugging is a read only property, so I can't change it.
I would simply like to replace the #DIV/0! message with an empty string or something like "-". How can I accomplish this?
Hm, sorry about that, I made a bad assumptoin and I was totally wrong on that one.
I just tested it out with your code and I get the same results. The event does not fire. This looks like a bug to me. You should Submit an incident to Infragistics Developer Support so they can check it out and get it corrected.
This is pulled directly from the helpfile for FormulaCalculationError. It makes it appear quite plainly that division by zero should fire this event.
using Infragistics.CalcEngine;using Infragistics.Win.UltraWinCalcManager;private void ultraCalcManager1_FormulaCalculationError(object sender, Infragistics.CalcEngine.FormulaCalculationErrorEventArgs e) { switch ( e.ErrorInfo.Code ) { case UltraCalcErrorCode.Div: //e.ErrorDisplayIcon = errorIconDivideByZero; e.ErrorDisplayText = "Divide by Zero Error"; e.ErrorValue = "#Div"; break; case UltraCalcErrorCode.NA: //e.ErrorDisplayIcon = errorIconNA; e.ErrorDisplayText = "A formula of NA was encountered"; e.ErrorValue = "#NA"; break; case UltraCalcErrorCode.Num: //e.ErrorDisplayIcon = errorIconInvalidNumericValue; e.ErrorDisplayText = "Invalid numeric values encountered"; e.ErrorValue = "#Num"; break; case UltraCalcErrorCode.Value: //e.ErrorDisplayIcon = errorIconInvalidArgument; e.ErrorDisplayText = "Invalid argument type encountered"; e.ErrorValue = "#Value"; break; } }
The FormulaCalculationError event fires when there is something the CalcManager cannot handle like a circularity. A division by 0 is not a FormulaCalculation error. The formula in this case is calculated just fine - it just that the result is an error code.
