60
Weird behavior on UltraTextEditor when right clicking
After upgrading from .NET Framework to .NET6 I get a weird behaviour when right clicking an infragistics control.
I have an UltraTextEditor control with a right click event set up that opens a ContextMenuStrip.
Now what's weird is that when right clicking the inside of the button, the right-click event doesn't register an my custom menu doesn't open up. Instead the default menu from Infragistircs opens up. But when I click just on the edges of the button, my custom menu opens up as it should and I land in the break point in the right-click event code.
Here are some images that help to clear that up
https://imgur.com/a/35c6okX
When the project was in .NET Framework everything worked fine. When I upgraded to .NET i didn't change any code regarding the controls.
I'm using Infragistics Nuget packages in the Version 23.1.52
What can i do to fix this behaviour.
Thanks!
