In a Winform App using Infragistics v20.1, I have an Ultragrid bound to a DataTable. The first column of the UltraGrid has a Ultradropdown column, which has a integer Data Column an a string Display column to ease input of a mandatory value. The Override is set to Multicellop = Cut+Copy+Paste. Manually filling the grid works fine.
Copy-Pasting a single row works fine as well. But as soon as I paste 2 or more rows, a popup states that the mandatory columns does not allow nulls. But the pasted data is not null in this column. As a single-row copy works, I guess there's some issue with multi-row-pasting.
How can I paste more than one row here?
Thanks for any hint.
Martin
Thanks Divya, I'll give it a try.
Regards
Hello Martin.
Thank you for your post . I have been looking into our document and if you are trying to add multiple rows into the grid in a single paste operation? That kind of operation is not currently supported.
Please refer to this other post Mike Slatzman provided a workaround:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/75378/copy-paste-for-ultragrid
Regards.
