Im assigning value to ultratexteditor, which I retrived from oracle database.
Data, Which i retrive is Unicode(Multiple language like chinese, French etc)
I can view the unicode data in debugging mode, before bound the value to ultratexteditor.
After bound data to texteditor, i can see only some rectangle, not the exact data.
Should i modify any property in ultratexteditor?
Thanks in advance.
Have you tried using an inbox TextBox control with the same text? If the inbox control works and UltraTextEditor does not, then it might be a bug.
Mike Saltzman"] Hi, The only thing I can think of is that perhaps your UltraTextEditor is using a Font that does not support unicode. Maybe you need to set the FontData.Name to a unicode-capable font.
I have the same problem and I am using Arial. That font should support unicode. Any other fonts, or suggestions that I can try?
