Hi Team,
I am using an ultratree having ultraformattedtexteditor as editor control. But when I am trying to edit the node
1. The node is not getting focused. Node text is not selected
2. Mouse click is not working if I need to set the cursor. I need to use the arrow keys to move the cursor.
3. Is there any way to increase the size of the box in edit mode.
Please refer the following screenshot.
Kaustubh
Thank you so much, I also want to know how you resolved it.Regards
John Matthew
Hi Divya,
Sorry. I missed to update here but, I have resolved the issue using the UseEditor property of the ultra tree node.
Thanks for your response.
Hello Kaustubh ,
Thank you for the update, i noticed that public posts having some issue sharing the uploads , therefore I created C-00237977 this private case ,which you can access from your infragistics account and share your sample .
Hi Divya,Thanks for your reply. Tried to upload the sample but getting following error.
Kaustubh Wadi
Hello Kaustubh,
Can you share your sample to have a look.
