Hi -
I have an UltraWinTree.UltraTree which has three level nodes. On Initializing, I have to show the tree in such a way that Nodes at level 1 and 2 are expanded and the nodes at level 3 so that the tree doen't look cluttered. All I saw is expandall and collapseall methods which applies to all nodes in the tree. Is there property to accomplish this one?
Thank you in advance.
An Override object is exposed by the control itself, so set UltraTree.Override.NodeDoubleClickAction.
//To expand and collapse treenode on double click
treeNode.Override.NodeDoubleClickAction = NodeDoubleClickAction.ToggleExpansionWhenExpansionIndicatorVisible;
i have set this property while loading the nodes but it works only for parent level nodes.
When or where can i set this property so that it is applicable to all the nodes??
Please reply ASAP.
Y_MB
This is what i want. Thanq.
There's an Expanded property on the node, itself. So you could expand the node at the time you add it to the tree if it's on level 1 or 2.
