Hi everyone, now I'm trying to understand why UltraDateTimeEditor in Windows Form is not working correctly. When the dropdown list of days is displayed and the user clicks on the current month at the top of the dropdown list between the arrows, then for some reason the last day of the month is automatically selected and the same happens with the month if you go to the list of years, selects the 12th month. Tell me how it can be solved.
Hello,I am able to reproduce the behavior you described. i have logged it with the id 34406,
please let me know if you have further question or concern.
Hello,At startup the date is set correctly. But when the user opens monthcalendar and goes from the tab with days to the tab for selecting a month, the date is set to 31 days, and it works the same way when going through any headings in monthcalendar. the last day, month, year and so on are automatically set. the red highlighted header when clicking on it automatically sets the last value for something.
i noticed that you have another post discussing the same issue here:
https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/126890/ultradatetimeeditor-defaults-to-a-date-value-when-clicked-on-the-header-controls-in-the-dropdown-area
You mentioned that you attached the images but unfortunately it dint come through , so please confirm you are saying instead of todays date its always selected the last day (30/31) of the month and same for the year, it always select Dec instead of current month?
Looks like i am able to reproduce the behavior against latest version V24.1.i am going to log it.
Also if you are using V7.2 them please note ve7.2 is been retired long back , its not supported and bug Fix anymore ,so in order to apply the fixed patch you would have to upgrade.
i am have created a private case C-00239718 to link the bug , you can access it from your infragistics account's case sections.
Let me know if you have any question.
