Promlem with Infragistics 22.2: The code "toolbarsManager.Tools.Exists (strKey)" returns false in releasemode and true in debugmode for tools whose Key contains a German Umlaut.With an older version of Infragistics (11.2) the application did nor show this problem.Do we have to limit keys of tools to ASCII characters? We use non-ASCII characters in keys of UltraGridColumns without any problem.
Hello Burkhard,
I’m not sure why this would be working differently in release mode or debug mode, but I have tested this with the latest version of 24.1, since 22.2 is not receiving active development and I was unable to reproduce the behavior.
I am attaching a sample that I used to test this. Can you please test this on your end to see if it is reproducible? If not, then I will request that you please modify this sample or provide an isolated one of your own that reliably reproduces the issue.
UltraToolbarsManagerFindToolTest.zip
