205
Sample projects not found
Many of the sample solutions reference a couple common projects: Infragistics.Extensions.Portable and Infragistics.Extensions.WinForms.  For example, the MultipleSeries.sln was installed here: C:\Program Files (x86)\Infragistics\2024.2\Windows Forms\Samples\VB\Chart\MultipleSeries\MultipleSeries.sln.  That solution file references the above projects at "..\..\..\..\Common\Extensions\Infragistics.Extensions\Infragistics.Extensions.Portable.csproj" and "..\..\..\..\Common\Extensions\Infragistics.Extensions.WinForms\Infragistics.Extensions.WinForms.csproj".  However, there is no "Common" folder in C:\Program Files (x86)\Infragistics\2024.2\Windows Forms, so those projects fail to load when opening the solution.  Where can I get those projects?
I think this might be similar to the problem described here: https://ko.infragistics.com/community/forums/f/ultimate-ui-for-windows-forms/125880/infragistics-2023-1-winforms-samples-infragistics-extensions-not-found.  But over the past couple days I've been unable to access certain pages on Infragistics' site due to a "scheduled maintenance" error so I can't see the details of that.  Not sure why that's inaccessible because I can access other posts that are significantly older.
Any assistance would be appreciated.
