55
Problem with high DPI / Scaling
I am using Infragistics 23.1 in my application. The app has a layout problem when the dpi / scaling of the monitor is changed from 100% to higher (125% or 150%). All the controls look bad-sized and the app is almost unusable.
Here is an example
In my app.manifest, I've added the following lines
<asmv3:application>
<asmv3:windowsSettings>
<dpiAware xmlns="">schemas.microsoft.com/.../dpiAware>
<dpiAwareness xmlns="">schemas.microsoft.com/.../dpiAwareness>
</asmv3:windowsSettings>
</asmv3:application>
I have tried to set the MaxInfragisticsDpiAwareness to all possible values, like this
Infragistics.Win.DpiUtilities.MaxInfragisticsDpiAwareness = Infragistics.Win.InfragisticsDpiAwareness.SystemDpiAware
But with no luck
Do you have any idea on how to solve the issue?
Claudio Di Flumeri
