200
urgent: how to use Node.Cells to store value, got exception from ultraTreeNode.Cells
This is my first time to use Ultratree. I created an ultratree, for each node, I need to save values: category_id,category_name, category_guid,category_description...
I put values into node in the following ways:
Node.Cells["Id"].Value  = idValue;
Node.Cells["Name"].Value  = nameValue;
Node.Cells["desc"].Value  = descValue;
Node.Cells["Guid"].Value  = guidValue;
then I got exception, the exception is like: Object is not set to an instance"
Should I create cells for the Node before I use Node.Cells[cell name]?
How to use Node.Cells?
  • 469350
    When are you getting this exception? On what line of code? That looks like a null references exception. So what is null when the exception occurs?
