can anyone help me in generating pdf from infragistics.document
using infragistics.document.PDF;
I have try to create pdfdocument with help of output stream, but i am getting emptypdf document only.
Actually i need to convert one aspx page ouput to pdf document.
(What you see what you get )
pdfDocument pdfDoc = new pdfDocument();
Response.AddHeader("Content-Type", "application/pdf"); Response.AddHeader("Content-Disposition", "inline;filename=HelloWorld.pdf"); pdfDoc .generate(Response.OutputStream, FileFormat.PDF);
I would like to convert the below html page into pdf format ....
<%@ Page Language="C#" AutoEventWireup="true" CodeFile="warpdemo.aspx.cs" Inherits="webgrid" %>
<%@ Register Assembly="Infragistics2.WebUI.WebCombo.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.WebCombo" TagPrefix="igcmbo" %><%@ Register Assembly="Infragistics2.WebUI.UltraWebGrid.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="igtbl" %><%@ Register Assembly="Infragistics2.WebUI.Misc.v7.3, Version=7.3.20073.38, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" Namespace="Infragistics.WebUI.Misc" TagPrefix="igmisc" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" ><head runat="server"> <title>Untitled Page</title></head><body> <form id="Form1" method="post" runat="server"> <table> <tr> <td valign="top" style="padding-top: 17px;"> <table> <tr> <td class="Label"> Select Customer ID: </td> <td style="padding-top: 7px;"> </td> </tr> </table> <igcmbo:WebCombo ID="WebCombo1" runat="server" BackColor="White" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px" DataSourceID="SqlDataSource2" ForeColor="Black" SelBackColor="DarkBlue" SelForeColor="White" Version="4.00" OnSelectedRowChanged="WebCombo1_SelectedRowChanged"> <Columns> <igtbl:UltraGridColumn BaseColumnName="customerId" DataType="System.Int32" IsBound="True" Key="customerId"> <header caption="customerId"></header> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="companyName" IsBound="True" Key="companyName"> <header caption="companyName"><RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="1"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="contactName" IsBound="True" Key="contactName"> <header caption="contactName"><RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="2"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="address" IsBound="True" Key="address"> <header caption="address"><RowLayoutColumnInfo OriginX="3"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="3"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Projectdescription" IsBound="True" Key="Projectdescription"> <header caption="Projectdescription"><RowLayoutColumnInfo OriginX="4"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="4"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Project" IsBound="True" Key="Project"> <header caption="Project"><RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="5"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> <igtbl:UltraGridColumn BaseColumnName="Officename" IsBound="True" Key="Officename"> <header caption="Officename"><RowLayoutColumnInfo OriginX="6"></RowLayoutColumnInfo></header> <footer><RowLayoutColumnInfo OriginX="6"></RowLayoutColumnInfo></footer> </igtbl:UltraGridColumn> </Columns> <ExpandEffects ShadowColor="LightGray" /> <DropDownLayout BaseTableName="" BorderCollapse="Separate" RowHeightDefault="20px" Version="4.00" XmlLoadOnDemandType="Synchronous"> <FrameStyle BackColor="Silver" BorderStyle="Ridge" BorderWidth="2px" Cursor="Default" Font-Names="Verdana" Font-Size="10pt" Height="130px" Width="325px"> </FrameStyle> <HeaderStyle BackColor="LightGray" BorderStyle="Solid"> <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" /> </HeaderStyle> <RowStyle BackColor="White" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px"> <BorderDetails WidthLeft="0px" WidthTop="0px" /> </RowStyle> <SelectedRowStyle BackColor="DarkBlue" ForeColor="White" /> </DropDownLayout> </igcmbo:WebCombo> </td> <td> <table> <tr><td> </td></tr> </table> </td> </tr> <tr> <td valign="top" > <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel1" runat="server" Width="550px" Height="100px" BorderStyle="Solid" BorderWidth="1px" TriggerControlIDs="WebCombo1" LinkedRefreshControlID="WebAsyncRefreshPanel2" BorderColor="#E0E0E0"> <table style="width: 464px; height: 96px"> <tr> <td class="Label"> Comapny Name: </td> <td class="ValueLabel"> <asp:Label ID="lblCompanyName" runat="server" /> </td> <td class="Label"> Contact Name </td> <td class="ValueLabel"> <asp:Label ID="lblName" runat="server" /> </td> </tr> <tr> <td class="Label"> Project </td> <td class="ValueLabel"> <asp:Label ID="lblProject" runat="server" /> </td> </tr> <tr> <td class="Label" style="height: 32px"> Project Description </td> <td class="ValueLabel" style="height: 32px"> <asp:Label ID="lblDescription" runat="server" /> </td> </tr> <tr> <td class="Label" style="height: 32px"> Office Name </td> <td class="ValueLabel" style="height: 32px"> <asp:Label ID="lbloffice" runat="server" /> </td> </tr> </table> </igmisc:WebAsyncRefreshPanel> </td> </tr> <tr> <td valign="top" style="padding-top: 23px;"> <igmisc:WebAsyncRefreshPanel ID="WebAsyncRefreshPanel2" runat="server" Width="501px" Height="183px" BorderStyle="Solid" BorderWidth="1px" RefreshTargetIDs="lblTotal" BorderColor="#E0E0E0"> <igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" DataMember="Orders" ImageDirectory="../../styles/office2007black/WebGrid/"> <DisplayLayout AllowDeleteDefault="Yes" StationaryMargins="Header" StationaryMarginsOutlookGroupBy="True" AllowSortingDefault="OnClient" RowHeightDefault="20px" Version="4.00" ViewType="OutlookGroupBy" SelectTypeRowDefault="Extended" AllowColumnMovingDefault="OnServer" HeaderClickActionDefault="SortMulti" BorderCollapseDefault="Separate" AllowColSizingDefault="Free" RowSelectorsDefault="No" Name="UltraWebGrid1" TableLayout="Fixed" AllowUpdateDefault="Yes" CellClickActionDefault="RowSelect" CompactRendering="False" GridLinesDefault="NotSet"> <AddNewBox Hidden="False"> <ButtonStyle CssClass="igwgAddNewBtnBlack2k7"> </ButtonStyle> <BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth="1px"> <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" /> </BoxStyle> </AddNewBox> <Pager> <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px"> <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" /> </PagerStyle> </Pager> <HeaderStyleDefault CssClass="igwgHdrBlack2k7"> <BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails> </HeaderStyleDefault> <GroupByRowStyleDefault CssClass="igwgGrpRowBlack2k7"> </GroupByRowStyleDefault> <FrameStyle CssClass="igwgFrameBlack2k7"> </FrameStyle> <FilterOptionsDefault DropDownRowCount="15"> <FilterHighlightRowStyle CssClass="igwgFltrRowHiLtBlack2k7"> </FilterHighlightRowStyle> <FilterDropDownStyle CssClass="igwgFltrDrpDwnBlack2k7"> </FilterDropDownStyle> </FilterOptionsDefault> <FooterStyleDefault CssClass="igwgFooterBlack2k7"> <BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails> </FooterStyleDefault> <GroupByBox> <BandLabelStyle CssClass="igwgGrpBoxBandLblBlack2k7"> </BandLabelStyle> <BoxStyle BackColor="ActiveBorder" BorderColor="Window"> </BoxStyle> </GroupByBox> <Images ImageDirectory="../../styles/office2007black/WebGrid/" /> <EditCellStyleDefault CssClass="igwgCellEdtBlack2k7"> </EditCellStyleDefault> <RowStyleDefault CssClass="igwgRowBlack2k7"> <Padding Left="3px"></Padding> <BorderDetails ColorTop="Window" ColorLeft="Window"></BorderDetails> </RowStyleDefault> <ActivationObject BorderColor="181, 196, 223" BorderWidth=""> <BorderDetails WidthLeft="0px" WidthRight="0px" /> </ActivationObject> <RowExpAreaStyleDefault CssClass="igwgRowExpBlack2k7"> </RowExpAreaStyleDefault> <SelectedGroupByRowStyleDefault CssClass="igwgGrpRowSelBlack2k7"> </SelectedGroupByRowStyleDefault> <RowSelectorStyleDefault CssClass="igwgRowSlctrBlack2k7"> </RowSelectorStyleDefault> <FixedHeaderStyleDefault CssClass="igwgHdrFxdBlack2k7"> </FixedHeaderStyleDefault> <SelectedRowStyleDefault CssClass="igwgRowSelBlack2k7"> </SelectedRowStyleDefault> <RowAlternateStyleDefault CssClass="igwgRowAltBlack2k7"> </RowAlternateStyleDefault> <SelectedHeaderStyleDefault CssClass="igwgHdrSelBlack2k7"> </SelectedHeaderStyleDefault> <FormulaErrorStyleDefault CssClass="igwgFormulaErrBlack2k7"> </FormulaErrorStyleDefault> <FixedCellStyleDefault CssClass="igwgCellFxdBlack2k7"> </FixedCellStyleDefault> <FixedFooterStyleDefault CssClass="igwgFtrFxdBlack2k7"> </FixedFooterStyleDefault> </DisplayLayout> <Bands> <igtbl:UltraGridBand> <AddNewRow View="NotSet" Visible="NotSet"> </AddNewRow> </igtbl:UltraGridBand> </Bands> </igtbl:UltraWebGrid> </igmisc:WebAsyncRefreshPanel> </td> </tr> <tr> <td valign="top" style="padding-top: 18px;"> TOTAL: <asp:Label ID="lblTotal" Width="50px" runat="server" BorderWidth="1px" BorderStyle="Solid" /></td> </tr> </table> <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:ProductManagementConnectionString8 %>" SelectCommand="SELECT [customerId] FROM [Customer_Details]"></asp:SqlDataSource> <asp:SqlDataSource ID="SqlDataSource2" runat="server" ConnectionString="<%$ ConnectionStrings:ProductManagementConnectionString9 %>" SelectCommand="SELECT [customerId], [companyName], [contactName], [address], [Projectdescription], [Project], [Officename] FROM [Customer_Details]"> </asp:SqlDataSource> <asp:Button ID="Button1" runat="server" OnClick="Button1_Click" Text="Generate Report" /> </form></body>
</html>
Thanks in Advance .
Right now there's no automatic conversion from HTML to PDF. You would need to parse through the HTML and create elements in the PDF document that match.
-Tony
I'm still not sure what your question is. What html output are you referring to? Which controls are you using?
Sorry for the belated reply. I was in holydays.
I wants to convert whole html output to pdf document. how can i do that ?
