715
custom layer not working..
i created a custom layer and i am adding a polyline to custom layer but it doesn't seems to work.
 Custom Layer Code
public void FillSceneGraph(SceneGraph scene)
if (Grid.Count == 0)
return;
IAdvanceAxis xAxis = Grid["X"] as IAdvanceAxis;
IAdvanceAxis yAxis = Grid["Y"] as IAdvanceAxis;
Polyline myPolyLine = null;
List<DataPoint> lsNewPoints = new List<DataPoint>();
int[ points = new [{5, 15, 25, 35, 45};foreach (int val in points)
int x = (int)(double)yAxis.MapInverse(val);
int y = (int)(double)yAxis.MapInverse(val);
DataPoint newPoint = new DataPoint(x, y);
lsNewPoints.Add(newPoint);
scene.Add(newPoint);
myPolyLine =
new Polyline(lsNewPoints.ToArray());myPolyLine.PE.Stroke = Color.Blue;
myPolyLine.PE.StrokeWidth = 2;
scene.Add(myPolyLine);
Main Chart Code
private void Form4_Load(object sender, EventArgs e)
DataTable dt = new DataTable();
dt.Columns.Add("First", typeof(double));
dt.Columns.Add("Second", typeof(double));
dt.Rows.Add(1, 1);
dt.Rows.Add(10, 10);
dt.Rows.Add(20, 20);
dt.Rows.Add(30, 30);
dt.Rows.Add(40, 40);
dt.Rows.Add(50, 50);
ultraChart1.ChartType =
ChartType.ScatterChart;
ultraChart1.ScatterChart.ColumnX = 1;
ultraChart1.ScatterChart.ColumnY = 0;
ultraChart1.ScatterChart.ConnectWithLines =
true;
ultraChart1.DataSource = dt;
ultraChart1.Layer[
"CustomLayer"] = new CustomLayer();ultraChart1.UserLayerIndex = new string[ {"Default", "CustomLayer"};
ultraChart1.InvalidateLayers();
I am  not sure why custom layer is not adding the polyline..
It would be helpful if any one can point me in right direction... Let me know if you need more info...
KK
  • 28496
    check the actual points you are passing into that line and see if they would fit on the chart.  i think you should be using the axis.Map function instead of MapInverse.
