I was wondering whether WinTree supports any method that lets InitializeDataNode event to fire for a particular node, all the hierarchy nodes and all the childrens of a particular node. In WinGrid the same could be accomplished by calling Refresh method and pasing appropriate parameters. This behaviour is critical to the functionality which I am implementing, and any help in this regard would be greatly apprecialted.
Thanks in advance,
spm
I would think the tree would have a similar Refresh method on the Nodes collection. If there is currently no such method, it must be an oversight. You should submit this issue to Infragistics Developer Support so they can check it out.
Submit a Support Issue
