See attached image (grey is UserGroups and yellow is Users).
I have a question abt structuring hierarchical data. I have the following example:
2 tables: UserGroup and User
A User can be "Member" of multiple user group - how would this be structured so I get the result shown in figure 2 in my grid?
Nomally I would add another table between the two called something like UserGroupMemberREF that mapped the user to the UserGroups is was member of, but if I do that then I will see that table represented as a row also placed between the Group and the user.
I have another program where I do the same but are using objects and the "UserGroupMemberREF" is a collection so the Grid recognizes this and renders it like in figure 2 and skips the row between. But when I am using datatable it isn't recognizing it as a collection of course...
I need to use DataTables for this, so what could a solution be? There must be a simple solution - it a very common and simple scenario... It's the *-* reference that I'm strugling with...
Thanks, Peter Haislund
Hi Peter,
This is really more a of a SQL question than a question about the grid. I'm pretty sure there are ways to do this with SQL. Generally, what you would have to do is bring back a joined child table that includes both the child data and the mapping table data as one table. This will probably not be editable, though - I don't know if you need it to be.
Another alternative would be to use the UltraDataSource in On-Demand mode as your grid's Data Source. This way you coud define a data structure with only two bands and when the grid asks the data source for a set of child rows, you could use the DataSet to determine the actual child data rows and return them - thus the grid only shows two levels, but the real data source with three levels is available in the background.
