995
Unable to sort databound tree nodes...
I have a simple test here and cannot seem to get the nodes to accept sorting when they are bound. I even tried sorting the DataView of the table and binding to that but still no luck. Here is my example. I have 1 ultratree on the form called treeActive and am calling my Override.Sort  =Ascending in the InitializeNode section:
Imports Infragistics.Win
Imports Infragistics.Win.UltraWinTree
Public Class Form1
Public dsFilesToBurn As New DataSet("dsFilesToBurn")
Public tbl As New DataTable("FilesToBurn")
Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
CreateDataSet()
AddRows()
treeActive.SetDataBinding(dsFilesToBurn,
"FilesToBurn")
treeActive.ExpandAll(ExpandAllType.Always)
'treeActive.Override.SortComparer = New NodeSorter(treeActive.Nodes(1), "Ascending")
'treeActive.Override.Sort = SortType.Ascending
End Sub
Private Sub CreateDataSet()
Dim c As DataColumn
c = New DataColumn("FileName")
With c
.DataType = GetType(String)
End With
tbl.Columns.Add(c)
c =
New DataColumn("FileNameGUID")
With c
End With
tbl.Columns.Add(c)
c =
New DataColumn("FileParentGUID")
With c
End With
tbl.Columns.Add(c)
c =
New DataColumn("FileType")
With c
End With
tbl.Columns.Add(c)
c =
New DataColumn("FileID") With c
c.AllowDBNull = False
c.DataType = GetType(Integer)
c.AutoIncrement = True
c.ReadOnly = True
End With
tbl.Columns.Add(c)
tbl.PrimaryKey =
New DataColumn() {c}
c = New DataColumn("FilePathCD")
c.DataType = GetType(String)
c.MaxLength = 500
tbl.Columns.Add(c)
c =
New DataColumn("FileIcon")c.DataType = GetType(Image)
tbl.Columns.Add(c)
c = New DataColumn("DirGUID")
c.MaxLength = 50
tbl.Columns.Add(c)
'THIS SHOULD BE SET TO "<SOFTWARE LIBRARY>" IF IT IS FROM THE LIBRARY
c = New DataColumn("FilePathLocal")c.DataType = GetType(String)
c.MaxLength = 500
tbl.Columns.Add(c)
c =
New DataColumn("CDGUID")c.DataType = GetType(String)
c.MaxLength = 50
tbl.Columns.Add(c)
c =
New DataColumn("IsDownloaded")c.DataType = GetType(Boolean)
tbl.Columns.Add(c)
c = New DataColumn("FileSizeInt")
c.DataType = GetType(UInteger)
tbl.Columns.Add(c)
c =
New DataColumn("FileSizeStr")c.DataType = GetType(String)
tbl.Columns.Add(c)
dsFilesToBurn.Tables.Add(tbl)
Dim dr As New DataRelation("dr", tbl.Columns("FileNameGUID"), tbl.Columns("FileParentGUID"))
dsFilesToBurn.Relations.Add(dr)
End Sub
Private Sub AddRows() Dim r As DataRow = dsFilesToBurn.Tables(0).NewRow
r("FileName") = "My InHouse App"
r("FileType") = "Folder"
r("FileNameGUID") = "1234"
dsFilesToBurn.Tables(0).Rows.Add(r)
r = dsFilesToBurn.Tables(0).NewRow
r("FileName") = "MyFile Folder"
r("FileNameGUID") = "1222"
r("FileParentGUID") = "1234"
r("FileName") = "BrownFile.exe"
r("FileType") = "File"
r("FileNameGUID") = "1212"
r("FileSizeStr") = "54.2 MB"
r("FileSizeInt") = 56623104
r("FileName") = "ADumbFile.exe"
r("FileNameGUID") = "1616"
r("FileName") = "CoolFile.exe"
r("FileNameGUID") = "1414"
r("FileParentGUID") = "1222"
r("FileName") = "A New File.abc"
r("FileNameGUID") = "1111"
r("FileSizeStr") = "13.4 MB"
r("FileSizeInt") = 14050914
r("FileName") = "ABigFle.123"
r("FileNameGUID") = "1223"
r("FileSizeStr") = "700 MB"
r("FileSizeInt") = 734003200
r("FileName") = "NewAFile.exe"
r("FileNameGUID") = "1515"
r("FileName") = "JohnsFile.exe"
r("FileNameGUID") = "1717"
r("FileName") = "Some File.exe"
r("FileNameGUID") = "1181"
End Sub
Private Sub treeActive_InitializeDataNode(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinTree.InitializeDataNodeEventArgs) Handles treeActive.InitializeDataNode
Try
If e.Node.IsRootLevelNode AndAlso e.Node.HasNodes Then
e.Node.Override.ShowExpansionIndicator = Infragistics.Win.UltraWinTree.ShowExpansionIndicator.CheckOnDisplay
End If
If (e.Node.Level = 0) AndAlso Not (e.Node.Cells("FileParentGUID").Value Is DBNull.Value) Then
e.Node.Visible = False
Else
e.Node.Visible = True
End If
Catch
End Try
Try
'JUST TRY TO SORT EVERYTHING ASCENDING
e.Node.Override.Sort = SortType.Ascending
Catch ex As Exception
End Try
End Sub
End Class
