880
Import Tools and Toolbars problem
I want to save a toolbar with one drop down button and import it into multiple existing Toolbar Managers. I've created a Toolbar Manager with just the toolbar that I want to save and used Load/Save Configuration to save the toolbar (try saving as binary and xml).
The problem is that if I use the Import Tools and Toolbars wizard then when I get to the Select Toolbars screen it dies as soon as a try to select a toolbar (it just disappears with no error message).
The saved file works if I use Load/Save fromthe Cusomize screen but then the existing toolbars are discarded.
Does anyone know how to get the Import Tools and Toolbars wizard to work?
I'm using Infragistics version 8.2.20082.1000 with Visual Studio 2008 SP1 (although I had the same problem before applying the VS2008 SP). The toolbar consists of a single drop down menu with an icon.
John.
