I need to select the row 1,3,5 (not continues) using keyboard.
regards,
pgr2007
If your grid is set up to allow multiple selection, then you can do this the same way you would do non-contiguous selection in any other application in Windows. Hold down the CTRL key and use the arrow keys to navigate rows. Use Space to select/de-select a row.
