What you do is, export the grids to a Report Document using the UltraGridDocumentExporter. You can export all the grids to the same section, once you have create the Report Document look at the samples that came with the infragistics lib...look at the grid samples and look for printing grid export to pdf something like that in order to preview the report if you would like.
