What is the easiest way to do absolute value sort for numeric columns when the user presses the column header?
Thanks in advance
Nish
Mike,
I am new to UltraGrid, I need to sort a grid column by Absolute value too, can you supply a code sample of SortComparer, and IComparer that will do this ....
Bob
Hi Nish,
You could do this using a SortComparer. You would create class that implement IComparer and then implement the Compare method. The x and y values passed in to the method will be two cells and you just get the values of the cells and get the absolute value and call compare on those values.
