I need to to create a chart which looks like a stack area chart. But in stack area chart the second set of data points move relative to the first set of data points. Is there any way I can plot the absolute data points, I mean the second set of data points should be plotted relative to the xaxis instead of the first set of data points?
Thanks Max, This issue got resolved. Am now using a line chart instead of stack area chart.
Sounds like what you are describing is a regular (non-stacked) area chart, although I'm not sure what you mean by 'relative to the x axis'. The X axis values are typically column indeces, while the data values are plotted along the Y axis. Can you post a picture of what you're trying to do?
