565
UDM_PaneDeactivate and UDM_PaneActivate
Hello and I hope someone can help me. I am really at wits end.
 When I activate the pane I set all controls behind it to be invisible. When I deactivate I tell it to make all controls behind it to be visible.
However, if I should click the start menu button while the pane is activated all the controls behind it return to the visible state. How do I fix this? I've tried addressing the form deactivate, isvisible and LostFocus events (If MakeVisible = False then make these controls invisible) with the same logic in the PaneActivate and PaneDeactivate events to no avail.
Public MakeVisible As Boolean = True
Private Sub UDM_PaneActivate(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinDock.ControlPaneEventArgs) Handles UDM.PaneActivate
MakeVisible = False
Me.Panel1.Visible = False
Me.pnlCheckBoxes.Visible = False
Me.lstColumns.Visible = False
Me.Label45.Visible = False
Me.cbSortChecked.Visible = False
Me.btnCheckedFieldForSortAdd.Visible = False
Me.btnChangeColumnOrder.Visible = False
Me.btnEmployeeDone.Visible = False
Me.btnResetSQL.Visible = False
Me.tbQueryText.Visible = False
Me.Button2.Visible = False
Me.Button3.Visible = False
Label60.Visible = False
Me.cbLeftDropDown.Visible = False
Me.Label61.Visible = False
Me.cbRightDropDown.Visible = False
Me.Label59.Visible = False
Me.chkEffectiveDating.Visible = False
Me.DateTimePickerEffectiveDate.Visible = False
End Sub
Private Sub UDM_PaneDeactivate(ByVal sender As Object, ByVal e As Infragistics.Win.UltraWinDock.ControlPaneEventArgs) Handles UDM.PaneDeactivate
MakeVisible = True
Me.Panel1.Visible = True
Me.pnlCheckBoxes.Visible = True
Me.lstColumns.Visible = True
Me.Label45.Visible = True
Me.cbSortChecked.Visible = True
Me.btnCheckedFieldForSortAdd.Visible = True
Me.btnChangeColumnOrder.Visible = True
Me.btnEmployeeDone.Visible = True
Me.btnResetSQL.Visible = True
Me.tbQueryText.Visible = True
Me.Button2.Visible = True
Me.Button3.Visible = True
Label60.Visible = True
Me.cbLeftDropDown.Visible = True
Me.Label61.Visible = True
Me.cbRightDropDown.Visible = True
Me.Label59.Visible = True
Me.chkEffectiveDating.Visible = True
Me.DateTimePickerEffectiveDate.Visible = True
End Sub
