While running the "Create Visual Studio Toolbox Tab" utlity from the start menu, I get the error message:
An error occured while attempting to add the Infragistics components to the toolbox
The message box shown also points to this log file:
C:\Users\ukeim\Documents\Infragistics\Tools\Toolbox Utility\Toolbox Utility.log
Which is actually zero bytes in length. I.e. completely empty.
Question: Any hints on what I can do to resolve and get the Infragistics toolbox tab in Visual Studio?
My configuration is:
ThanksUwe
Hmm, I did try the trick with the /t:9 switch ... but without success.
I also have VS2008 (SP1) installed and this is my error-stack:
--- cut ---
18:06:17 - EXCEPTION: System.Runtime.InteropServices.COMException Source: mscorlib Message: Eine Instanz der COM-Komponente mit der CLSID {1A5AC6AE-7B95-478C-B422-0E994FD727D6} konnte aufgrund des folgenden Fehlers nicht von der IClassFactory erstellt werden: 80010001. Stack Trace: bei System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck) bei System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache) bei System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache) bei System.Activator.CreateInstance(Type type, Boolean nonPublic) bei TBUtility.ToolboxUtilityManager.ProcessArguments() --- cut ---
This references als CLSID {1A5AC6AE-7B95-478C-B422-0E994FD727D6} which is supposed to be the VS2008 IDE ... :(
"/t:9" actually did the trick!
Thank you very much, Andre!
I've submited a support request and will post the results later!
Uwe:
Try running the toolbox utility from the command line with the "/t:9" parameter. This should install the controls in VS 2008, only
C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 2 CLR 2.0\Toolbox Utility> infragistics2.toolboxutility.exe /t:9.0 8.2
After reading this one, it seems that "{BA018599-1DB3-44f9-83B4-461454C84BF8}" indicates VS 2005, which I do not have installed.
Maybe the Toolbox Utility fails if it finds no VS 2005, even if VS 2008 is installed.
