25
AllProperties and Business Classes
I am working on a windows form project and I want to use the AllProperties property from the CalendarInfo.DataBindingsForAppointments class. I have not been able to find a single code example of how this will work using the business classes and not data sets.
My boss has asked me to use business classes and not datasets so I don't have the option to use datasets.
Can someone please post an example or point me in the direction of an example?
Thank you.
  • 1922
    Hi, I use the following code to setup my binding:
     appointmentBindingSource.DataSource = appointmentList;
    ultraCalendarInfo.DataBindingsForAppointments.AllPropertiesMember = "AllProperties";
    ultraCalendarInfo.DataBindingsForAppointments.StartDateTimeMember = "StartDateTime";
    ultraCalendarInfo.DataBindingsForAppointments.EndDateTimeMember = "EndDateTime";
    ultraCalendarInfo.DataBindingsForAppointments.SubjectMember = "Subject";
    ultraCalendarInfo.DataBindingsForAppointments.AllDayEventMember = "IsAllDayEvent";
    ultraCalendarInfo.DataBindingsForAppointments.OwnerKeyMember = "OwnerKey";
    ultraCalendarInfo.DataBindingsForAppointments.SetDataBinding(appointmentBindingSource, string.Empty);
    this.ultraCalendarInfo.DataBindingsForAppointments.BindingContextControl = this;
     appointmentList is a BindingList<T> where T is  an AppointmentVO.
    The AppointmentVO is defined as follows:
    public class AppointmentVO
    private int appointmentIdField = int.MinValue;
    /// <summary>
    /// Gets or sets the appointment ID.
    /// </summary>
    /// <value>The appointment ID.</value>
    public int AppointmentId
    get { return appointmentIdField; }set { appointmentIdField = value; }
    private bool isNewField = true;
    /// <summary>
    /// Gets or sets a value indicating whether this instance is new. The value is false if the VO has been loaded from the DB.
    /// </summary>
    /// <value><c>true</c> if this instance is new; otherwise, <c>false</c>.</value>
    public bool IsNew
    get { return isNewField; }set { isNewField = value; }
    private string ownerKeyField = string.Empty;
    /// <summary>
    /// Gets or sets the owner key.
    /// </summary>
    /// <value>The owner key.</value>
    public string OwnerKey
    get { return ownerKeyField; }set { ownerKeyField = value; }
    private byte[ allPropertiesField = new byte[1];public byte[ AllProperties
    get { return allPropertiesField; }
    set { allPropertiesField = value; }
    private string subjectField = string.Empty;
    /// <summary>
    /// Gets or sets the subject.
    /// </summary>
    /// <value>The subject.</value>
    public string Subject
    get { return subjectField; }set { subjectField = value; }
    private bool isAllDayEvent;
    /// <summary>
    /// Gets or sets a value indicating whether this instance is an all day event.
    /// </summary>
    /// <value>
    /// <c>true</c> if this instance is an all day event; otherwise, <c>false</c>.
    /// </value>
    public bool IsAllDayEvent
    get { return isAllDayEvent; }set { isAllDayEvent = value; }
    private DateTime startDateTimeField = DateTime.MinValue;
    /// <summary>
    /// Gets or sets the start date time.
    /// </summary>
    /// <value>The start date time.</value>
    public DateTime StartDateTime
    get { return startDateTimeField; }set { startDateTimeField = value; }
    private DateTime endDateTimeField = DateTime.MinValue;
    /// <summary>
    /// Gets or sets the end date time.
    /// </summary>
    /// <value>The end date time.</value>
    public DateTime EndDateTime
    get { return endDateTimeField; }set { endDateTimeField = value; }
    hope this helps!
