380
Need a way to display ToolTip to UltraWinToolBars.MaskedEditTool
    I have a MaskedEditTool inside my UltraWinToolBars. Based on certain logic I need to focus this toolbar item and set a balloon tool tip to the control using UltraToolTip manager automatically, pointing to the user that control has to be filled in with somedata.
The main issue I am facing is that both
UltraToolTipManager.SetUltraToolTip(...) and
UltraToolTipManager.ShowToolTip(..)   accepts a Windows control and MaskedEditTool  cannot be converted to one.  There is a Control property within MaskedEditTool  but it does not point to any control at runtime.  Is there any other API or alternate method I can use to show this tooltip.
Saravanan.
  • 48586
    One possible way to achieve your goal is to use the form as a parameter control. I have created a small sample to illustrate how your goal could be achieved. Please run the sample and press the button “button1”.
    Thank you for using Infragistics Components
    WinToolbarsManagerMaskedEditTool.zip
