3455
Tooltip of Minimize, Maximize and Close buttons is truncated.
I have a problem in WinToolbar control.
In my application the tool tip of Minimize, Maximize and Close button is getting truncated, if the window is right alligned.
Also the Close button tooltip is truncated while window is in maximized state.
regards,
pgr2007
  • 44743
    I believe a similar issue has been fixed recently. I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp. If it is the same issue, you will be notified when the hotfix is released. If not, it sounds like a bug and should be fixed.
