800
Another Toolbox Utility problem
I've recently updated to NetAdvantage 2008.2 (from 2008.1), and since then I haven't been able to get the toolbox to work correctly.  I've tried running the toolbox utilty multiple times, trying different switches but to no avail.  The utility says that the tab was created successfully, the output indicates that everything was added, but once I get into Visual Studio, there is a tab, but it is completely empty.  I've had to manually add the controls, but that is a PITA, since because of the sheer number of controls - so I've only added a bare minimum that I use more often.
The only difference from the 2008.1 install, is that I've since installed ReSharper.
My setup is:
VS2005 Pro (not used much anymore)
VS2008 Pro with Resharper 4.1 add-in.
