75
Selecting a tree's node in code
I have a two Ultratree controls...the first tree control is on a form that is restricted in height and width.  So I have a popup component that floats over the form and the height and width is much bigger to all the user to see more detail of the data.  The goal is that when I select a node from the popup form is that it is transfered back to the original form.  I have an event that passes back the selectednodes collection.  I was trying to loop through the orignal tree and have not been able to find anything on how I would programically select the original tree with the same selection from the popup tree.
Thanks for any help on this
Public Sub SetSelectedNode(ByVal selectedNodes As SelectedNodesCollection)
    For Each node As UltraWinTree.UltraTreeNode In selectedNodes
        If node.Selected Then
            For Each treenode As UltraWinTree.UltraTreeNode In ResultsTree.Nodes
                If node.FullPath = treenode.FullPath Then 'NOTE problem with this is some node paths with the same name.
                   'ResultsTree.ActiveNode.Selected = True  'NOTE Doesn't work
                   'ResultsTree.Nodes.Item(treenode.Key).Selected = True  'NOTE not sure this work plus I don't have the key set and dont know how.
                End If
            Next
       End If
   Next
End Sub
