I have 10 columns in an ultra grid, with 1st 4 needing to be in 1 group, and the last 6 in the 2nd group.
How do I add these UltraGridGroup using the designer to my ultragrid/band[0] using the designer?
I am a huge fan of visual designers, and promote avoiding writing code that can be done by a visual designer.
The code for the above would be exactly what's in the reference doc, but I would want to do this via the ultra grid designer:
private void button28_Click(object sender, System.EventArgs e) { // Get the band to have the groups in. UltraGridBand band = this.ultraGrid1.DisplayLayout.Bands[0]; UltraGridGroup group1 = null; UltraGridGroup group2 = null; // Clear existing groups if any. band.Groups.Clear( ); // Add two groups with two different keys. First arguement to the Add call is // the key and the second arguement is the caption of the group. group1 = band.Groups.Add( "Group1", "Address Info" ); group2 = band.Groups.Add( "Group2", "Contact Info" ); // If you don't want group headers displayed, set this to false. By default // it's true. band.GroupHeadersVisible = false; // Set the LevelCount to desired number of levels. Level 0 is the first row in // the group, while level 1 is the second row in the group and so on. Here we // are going to have 2 levels. band.LevelCount = 2; // Add ContactName column to the first level (level 0) of group1 with visible // position of 0 (meaning it will appear first in that level. There is only // one header in this particular level level anyways.) group1.Columns.Add( band.Columns["ContactName"], 0, 0 ); // Add City column to second level (level 1) with visible position of 0. And // also add the Country column to the same level with the visible position of // 1 so that it appears after City column. group1.Columns.Add( band.Columns["City"], 0, 1 ); group1.Columns.Add( band.Columns["Country"], 1, 1 ); // Add Fax and Phone columns to group2 on different levels. group2.Columns.Add( band.Columns["Fax"], 0, 0 ); group2.Columns.Add( band.Columns["Phone"], 0, 1 ); // Prevet the users from moving groups and columns by setting AllowGroupMoving // and AllowColMoving to NotAllowed. band.Override.AllowGroupMoving = AllowGroupMoving.NotAllowed; band.Override.AllowColMoving = AllowColMoving.NotAllowed; // One could change the various properties like RowSpacingAfter and // BorderStyleRow on the Override change the appearance. band.Override.RowSpacingAfter = 5; band.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.Raised; }
Thank Brother. It's really work. i got my solution of my problem...
Thank Brothere. It's really work. i got my solution of my problem...
You would do this from the Column Arrangement Overview on the band.
